1 - 18 of 18 Posts
well s0 here for now with agp wga... ran real strong with 17psi spike and 15.5 hold but cali gas pings it under 2nd gear full load :( had to settle for 15/14 for now.. hopefully stage1 fixes that...
17psi falling to 15 on 93 pump, 19psi falling to 15 on race fuel :eveilgrin , I accidently ran 19 on 93 once, no detonation, but I could feel the car surge as it pulled timing. But, on the race fuel, the car seems to do fine at 19psi. 2004 stage0 ed tip mod, agp wga.
ok my question since it seems established that every1 is running 17-18 spike falling to 14-15. Wich lines (green, blue) is every1 running off of or stock. If stock, how are you keeping the ecu from pulling boost after a few days?
im running off the intake mani source. i might go back to running off the stock WGA & boost control soon though......
Discussion Starter · #17 ·
I was running green, I am now running blue w/ EDTIP
IwantAn04, I've ran off blue...off green...then cap green and off back of turbo...all the same...currently I am off the back of the turbo and I capped the green line. Spools uber quick to 15psi :) then it creeps to 17 and holds there until about 4500rpms and then she comes back down...15psi by about 5400rpm and 14psi by shift time.
I do 17psi fall to 14psi. Go higher than 17psi in 4th gear and say hello to the power cut. :(
1 - 18 of 18 Posts
