Here are some specs i just gathered up
(these come from various sources and may be innacurate)
General
Body style: Four-door sedan
Assembly plant: Belvidere (Ill.) Assembly Plant
EPA vehicle class: Compact car
Dimensions
Overall length: 175.7 (4462.2)
Overall width: 67.4 (1712.0)
Overall height: 56.5 (1435.1)
Wheelbase: 105.0 (2667.0)
Front track: 57.6 (1464.0)
Rear track: 57.7 (1465.3)
Estimated Curb weight, lbs.: 2970
Powertrain
Transaxle: Heavy-duty five-speed manual NVG T850, front-wheel drive
Engine: 2.4-liter turbo, DOHC, 16-valve, in-line four-cylinder w/ Intercooler
Displacement: 148.2 cu. in. (2429 cu. cm)
Construction: Cast iron block and bedplate, aluminum alloy head, structural aluminum oil pan Compression ratio: 8.1:1
Power (SAE net): 215 bhp (160 kW)@ 5400 rpm
Torque (SAE net): 245 lb.-ft. (333 N-m) from 3200 - 4200 rpm (Peak torque maintained between 3200 & 4200)
Max. engine speed: 6250 rpm
Fuel requirement: Unleaded premium gasoline, 91 octane (R+M)/2
Gear ratios
1st: 3.647
2nd: 2.045
3rd: 1.367
4th: 0.947
5th: 0.756
Final drive ratio: 3.526
Reverse: 3.470
Suspension
Description: Performance-tuned strut and spring assemblies, heavy-duty sway bars, updated knuckles, unique K-member
Brakes
Description: Performance-tuned four-wheel disc with ABS
Front: 280mm x 28mm vented and 57mm w/ red single piston calipers
Rear: 270mm x 12mm solid and 36mm w/ red single piston calipers
Performance
0-60mph: 5.9 secs
1/4 mile: 14.6 [email protected]
Top Speed: 148mph
60-0mph: 119ft.
Slalom: 69.7mph
General
Dimensions
Powertrain
Gear ratios
1st: 3.647
2nd: 2.045
3rd: 1.367
4th: 0.947
5th: 0.756
Reverse: 3.470
Suspension
Brakes
Performance
0-60mph: 5.9 secs
Top Speed: 148mph
60-0mph: 119ft.
Slalom: 69.7mph
