I was just noticing that the SRT-4 has a lot it common with the PT Cruiser GT so i was just wondering if I ordered rims fitting a PT cruiser GT will they fit on an SRT-4. The Bolt pattern and offset were the same 5/100 and 42mm offset. Rims are 18s and the overall diameter was the same. Any thoughts?
you need to make sure that they clear the rear struts too....see PT cruisers dont have the same rear suspension setup as the neon....
Aftermarket? Stock rims on the PT's come no bigger than 17's (although the "Empire" wheels are wider at 7" than the other PT GT wheels). All the stock wheels interchange, so if it truly fits the PT without a problem you should be fine on the SRT4. If they are aftermarket you'd need to verify fitment although there's a good chance they'll work.
Standard PT GT 17x6's:
Special edition Empire wheels 17x7's
