1 - 3 of 3 Posts
I did a search and came up with nothing!
what is the type of spring that you guys are using on your cars? I know that there is one on ebay but I want to know what is the type of spring that you guys are running. what parts store can I get it from?
Most people are using springs for a Carburator. Throttle return spring. Just go to the local auto parts store and look around for the carb springs. You'll have to play around with the stiffness of the springs till you get one that wont boost too much.
spring pic
i used door spring from Home Depot... :thumbsup:
not on car anymore but here pic of spring i used...
one end on wastegate arm.. one end screwed under battery bolt (behind battery) :eveilgrin
if u need a lil more boost add breather.. use plastic connector to connect 1/4" hose and make a hole in it.. more holes more boost...
1 - 3 of 3 Posts
