2DR = 2 door
3AVJ = 3 Angle Valve Job
4DR = 4 door
5AVJ = 5 Angle Valve Job
5M = 5-speed manual tranny
A/F = Air/Fuel Ratio
ABS = Anti-lock Braking System
ACG = Adjustable Cam Gears
AFPR = Adjustable Fuel Pressure Regulator
ATx = Auto Trans.
AWD- All Wheel Drive
AWS = all wheel steering
BOV = blow off valve
CAI = Cold Air Intake
CF- Carbon Fiber
DOHC = dual over head cam
DOT = department of transportation
DP = Downpipe
EBC = Electronic Boost Controller
EBD = Electronic Brake Distribution
ECU = Engine Control Unit
EGT = Exhaust Gas Temperature
EM = Exhaust Manifold
EMS = Engine Management System
FMIC = front mount intercooler
FPR = Fuel Pressure Regulator
FWD = Front Wheel Drive
HID = High Intensity Discharge lighting
I/C = Intercooler
I/H/E = Intake/Header/Exhaust
ICE = In Car Entertainment
ICM = Idle Control MotorICU = Integrated Computer unit
IM = Intake Manifold
JDM = Japanese Domestic Market
LSD = limited slip differential
MAF = mass air flow
MBC = Manual Boost Controller
MT = Mickey Thompson
MTx = Manual Trans.
NISMO = Nissan Motorsports
P&P = Port and Polish
PVO = Performance Vehicle Operations
RAI = Ram Air Intake
RRFPR = Rising Rate Fuel Pressure Regulator
RWD = Rear Wheel Drive
SIPS = Side Impact Protection System
SOHC = single over head cam
SRS = Supplemental Restraint System
SRT = Street and Racing Technology
STi = Subaru Technika International
SV = surge valve
SVT = Special Vehicle Team
TB = Throttle body
TDC = top dead center
TIP = throttle inlet pressure
TMIC = Top Mount Intercooler
TPS = Throttle Position Sensor
TRAC = Traction Control System
UP = Uppipe
VC = Valve Cover
WG = Waste Gate
WOT = Wide Open Throttle
Thanks to everyone for the contributions.
If you would like to add some abbreviations, please reply in the same format that I have already listed so I can just cut and paste and I'll add yours to what we have so far.
4DR = 4 door
ATx = Auto Trans.
CF- Carbon Fiber
DP = Downpipe
I/C = Intercooler
MAF = mass air flow
MTx = Manual Trans.
SV = surge valve
TB = Throttle body
UP = Uppipe
VC = Valve Cover
WG = Waste Gate
