someone in chicago with tools and a garage, i need help!!
453 Views 2 Replies 2 Participants Last post by  xplosioninthesky
i'm in the process of moving to chicago from michigan, on the way out here the rh wheelbearing went.
i can't afford the 400+ dolars shops want for the repair.
if anyone out there has a garage and access to a press,i'll hook you up with cash and or beer.
you won't have to do anything,i'll do all the work, i just need access to tools.
i'm stranded in the middle of my move,if anyone could help me out i'd greatly appreciate it.
thanks,
sean
1 - 3 of 3 Posts
you can still drive with a bad wheel bearing, just dont do anything outrageous.. most places charge like $180 around here to do 1 wheel bearing (remove knuckle, press out bearing, press in new, reinstall). just had it done on my moms cause i was lazy
i had one changed at a stealership, 427 for hub and bearing. i'll have to scout around, could you recommend any places?
i'm right downtown, and the bearing is totally trashed.
1 - 3 of 3 Posts
