My SRT came with an AGP WGA off PCM Boost and the solenoids shoved in the hole behind the drived headlight. All color vacuum lines are gone. I got my stock cold side pipe, wga, blue plate and want to put it back to stock on PCM boost. How do I tell which solenoid is what?
TIA
Are they still attached to the bracket? If so, just look at the vacuum diagram under the hood. If not, you can look at the connectors, they are all slightly different. From there you can check the colors of the wires.
I think they have numbers on them too, but they may be worn off.
Thank you for the reply. I was able to get one of the guy from Modern Performance to take a picture of the wires for me on a car they had at the store. I will upload it here just in case someone else runs in to the same issue as me.
