Are your 26X10 dot cheater slicks the same size as your 26X8.5 racemaster slicks? Thanks
Here you go.
Slick.
Tread Width: 8.3"
Section Width: 10.5"
Diameter: 26.0"
Circumference: 82.0"
Rim Size: 8.0"
Code: MHR-62
Compound Type: HB-11
Cheater Slick
Tread Width: 8.5"
Diameter: 26.0"
Circumference: 81.8"
Rim Size: 8.0"
Code: MHD-01
SlicksMH
what rim would you recommend for a 26x10 cheater slicks. and from looking at the numbers if my 26x8.5 slicks fit. i only need less than 1/10 of inch extra clearance to the strut? for the added width of the 26x10 dot vs the slick>
so if my 26x8.5 mh slick fits the 26x10 cheater should too as long as there is a little extra room at the strut tower? less then a 1/8?
