1 - 7 of 7 Posts
I've spent the last hour searching posts about winter rim and tire sizes. It was very informative but I'm a little confused from different peoples responses. I want to go with a 15" rim which should fit with no problem. I've read you can use a pt cruiser 15" steelie as a rim. Some have said you need a spacer and other have not. Does anyone out there know for sure before I order some. I also came across some people using 15" VW jetta/gold 1.8 steelies. Will these work with no fittament issues. If anyone has any insight that would be great. I just don't want to order something and then have to return it because of fittament issues. Thanks :clap:
when a girl says it's a good size.. thats just a nice way of saying it's small.
oooh tires.. no idea..
The VW steelies work perfectly. No spacers/hub rings needed. I run a 205/60/15 which is very slighly smaller than sotck diameter (like 0.4 inches or something).
1 - 7 of 7 Posts
