Well number one, our aluminum heads dont like over heatings. Causes the vales seats to drop out since aluminum expands at a faster rate than the hardened steel seats.
Second, you can warp the head, the head gaskets on these cars never blow. Its a MLS gasket. Instead the head warps. It will have all the same symptoms of a blown head gasket, just its not the gasket.
Your lucky she didnt lock the motor up, or warp the head. Hell, or even burn a valve.
Keep an eye on your temp gauge though. If you get nervous about it i can give you a few tests to run to check and make sure everything is good.
Btw, what the hell caused the motor to overheat anyways? Or do you know that yet?
