what do you meen reads +20, the safc dosen't read anything, it only uses the numbers you put in it. theres no way your adding 20% and not getting a map sensor code. explain what you meen by reads +20.
This is incorrect. The S-AFC CAN add fuel, however, it is not recommended that you do this as it is reduces timing advance and can throw error codes.agp03 said:Thanx for the replies.
Well, I am looking at the correction factor or "corr" reading on my SAFC. It reads -30 at idle and around the teens at lo to mid throttle settings. It shows that it is "pulling" fuel, right? At WOT (I have a 50 trim) it goes to positive readings, anywhere from +4 to +25 depending upon boost settings - the higher the boost, the higher the positive number.
Since the SAFC cannot add fuel in our cars (correct?) when the correction factor goes to "zero" does that mean that the ECU essentially takes over and no fuel is being pulled at that point?
And what does it mean when it goes positive?
I do not get any codes per my scan guage. No CEL's.
For some reason, no one has been able to answer this, so appreciate the input.
Something is definitely not right with your setup...agp03 said:Allright! Thank you!!
I was running 20 psi on the fact guage, showing 18.5 on the Aeroforce Scan Guage. The Aeroforce was also displaying an Injector Duty Cycle of 110%. (Which is my next question - why is that?)
Did you want a total advance number at WOT? I can get that tomorrow eve as I am not driving the skittle today.
BTW, AFR's at high 10's and KR at 2-4 at 20psi.
Sure appreciate your help and knowledge, I don't know how many times I have heard that you cannot add fuel and that you will get codes.
