381 - 396 of 396 Posts
Thanks Amy. That's great news. Does your state require tests anually, bi-anually or ?
California does not require tests on new cars for several year and then it's bi-annual.
So the ttranny similator would be the way to go for me rather than reverting to stock ever two years.
Keep at it Phrozen. Don't give up. As with most things in life, it's always better to finish if at all possible.
Heh. Yeah, we'll finish it no problem. I just need more time.
Every version we have made since the start has worked. We're on our 4th revision and they all work.
I just keep optimizing for size, power, heat, adding features, and now I'm trying something very different...
You can see the 4th and 3rd generation designs in this post:
http://www.srtforums.com/forums/showpost.php?p=2664685&postcount=1
Thanks. So California is exempt for the first 6 years for the original owner and then there is a bi-anual inspection after that. Guess that means I've got a little over three years for Phrozen to perfect the simulator.
Finally got around to ordering the N2MB Code Scrubber today.
Better late than never.
Swapping the PCM, MAP, TIP and Injectors every 2 years has gotten real old.
Car runs miles better with the ALL the S3 components.
Sure hope N2MB is still around...
