Hello to Ethan. I spoke with Josh Jacquot of SCC and suggested that I post here.
He suggested you would likely respond back.
My questions for you are :
1) How sensitive is the WGA setting on Stage 2? Should it be set to exactly what the recommendation is? What is expected boost that one should see?
2) I had seen the side exhaust on the Mopar car. I believe it was 2.5 inch. Is the expected HP output running say an intake and nothing else to be 250HP at the wheels? Or Is another sized exhaust/downpipe recommended instead?
3) Will an aftermarket fuel pump installed in anticipation of more mods affect a S2 setup ( considering no other mods?) ( less HP too much fuel?)
4) During a dyno run many cars running similar setups had major disparity in their HP numbers. What could attribute this ( Anwhere from 220 ( less than S0) to 252 HP at the wheels. ( everyone also ran the same gas 91 octane)
5) Does the Pcm truly learn? Why does it retard timing unlike S1?
