I had a fwd dsm and it ran low 13s high 12s. I now am getting a srt-4 with stage 1, boost controller, w.g. actuator, intake, o2 housing, 3"exaust, FMIC, and S-AFC
my question is when driving around on pump gas at about 15 psi should I have the s-afc set 00000 all the way across the board or should I take out a few percent... what should my afr be... I understand this question leaves a lot of open ends so pretty much what is "safe"
If you leave it at 0, then its not doing anything, so you might as well take it off the car.
I would get a wideband/dyno and tune it with that. See if its running rich, and if so, pull some fuel out in the right areas.
There is an SAFC sticky in the high-tech tuning area..
But for general info...a/f ratios should be in the 11.5 or so range for a nice "safe" tune. Personally, I like using a wideband on the car doing 3rd/4th gear pulls and tuning on the road..as it puts a more "real world" load on the car than the dyno can. The track is the perfect place IMHO, but tuning on a dyno with a wideband readout is an effectively safe way to do it too.
