So long story short the car was running really cold and would never heat up.
Replaced the stuck open 160 degree fail safe type thermostat with a regular 180 degree thermostat.
All was good for a while.
Now....with more use of the AC since its been hot outside the car reaches 230 degrees and will not go down!
I noticed only one fan turns on....the other fan doesn't even turn on with it at 230 degrees or slightly higher than 230! When is the second fan suppose to engage?
On my other Srt4 with the Diablo tune both fans turned on......this was pretty ideal to cool down quick!
Is this a water pump issue now? 😳
