I tried to do a search but ECU comes up as too short of a term. If I want to reset my ECU do I just disconnect the battery and that's it?
Administrator
disconnect the battery for a few minutes or remove the fuel pump fuse for a little bit also, either one will work.
Turning the ignition ON OFF ON OFF ON will reset the timing. In my car, it actually WRITES IT on the ODO that it's DONE.
To reset the ECU/PCM, that's the only way I know of (D/C the battery for 15-20 min)
ht, the "done" indicates that it has no diagnostic codes to display:)
