so this is just to try to simplify the whole replacing vacuum lines. I have read through a lot of posts and just wanted to make sure i got everything when i do this since i only have one car and dont want to have to re-hook the stock lines to go get something i missed..
so i replace all the hard lines with 5/32" fuel hoses (i prefer the fuel hose over normal vacuum hoses. was thinking 30ft should be plenty since it is $1 or less per ft. unless someone knows how much ft is needed for sure). but get a little bit of 7/32" hose for the WasteGate and a 7/32" to 5/32" reducer. i saw someone mentioning using a 7/32" hose to connect to the turbo, is this needed, or will the 5/32" work? also, would the stock T connectors work with the 5/32" hoses or should i just play it safe and get new 5/32" T connectors since i am going to get a reducer anyways?
i think that should be all needed for a vacuum line replacement.. if there are any other connectors i should be getting, please let me know
my vacuum setup is for pcm controlled boost (fm wga) with aftermarket bov.
