This needs to be a sticky
Thanks to the MOPAR crew, here is the Turbo Kit replacement parts listing - hot off the presses.
Take Note: The parts are NOT available yet... Dealers have not been sent this info yet either, so don't expect them to know anything about this yet.
The vendors must build enough parts to support kit orders as the immediate priority, so the parts will become available in the near future. If you are dead in the water, call the MOPAR help line.
They provided this info on the forums as a favor to those that have been waiting patiently. Please understand that this is an initial list of parts.... If you want to see some more, then post your requests here.
Part Number Description MSRP
04546692 O-Ring Fuel Pump Mod 8.35
04852396AB Copper Washers (6) 2.35
04884447AA Gasket 9.75
P4510063 Fuel Rail Assembly, Demand Regulated 279.00
P4510365 Sensor, MAP 3.0 Bar 80.00
P4510366 Sensor, TIP 3.0 Bar 110.00
P4510529 +30% Fuel Injectors (Individual) 89.00
P4510554 Fuel Pump Module, High Flow, 75PSI, Demand Regulated 699.00
P4510595 Wastegate Actuator (P350) 129.00
P4510596 Wastegate Actuator, Stage 3, (P420) 289.00
P4510601 Bezel Assembly 199.00
P4510623 4-Way Connector 24.00
P4510626 Inline Water Filter 29.00
P4510627 Inline Check Valve 35.00
P4510632 Sprayer Pump 60.00
P4510659 TD05HR Turbo with Inconel Steel Wheel, IncludesTurbocharger (P4510279) and Elbow (P4510278) 1,799.00
P4510861 Terminals (wire harness), 1 Pkg = 10 pcs. 10.00
P4510862 Blue LED (wire harness) 4.00
P4510863 Red LED (wire harness) 4.00
P4510864 Turbo Cartridge, Iconel Turbine Wheel 750.00
P4510865 Turbo Cartridge, TiAl Turbine Wheel 1,650.00
P4510866 Turbo Hardware Kit: V-Clamp, Compressor Snap Ring, Actuactor Clip, Actuactor Bolts, and Elbow Bolts (5) 120.00
P4510867 Compressor Kit: Compressor Cover, Surge Bypass Valve, & Surge Valve Bolts (3) 225.00
P4510868 BOV Diaphragm 67.00
P4510869 Manifold Kit, Turbo Exhaust Elbow (P4510278), Manifold (P4510877), Elbow Bolts (5) 1,350.00
P4510922 Sprayer Brackets, Set of Two (2) 25.00
P4510923 Water Jets, Set of Four (4) 129.00
P4532586 +40% Fuel Injectors (Individual) 39.00
