So I replaced my valves on cylinder number 4. Did the spacing and all tht correctly. Put the head back in and put it on timing. Go to start the car and nothing. It cranks but wont start. It started for one second last night and today but shuts off quick. Fuel pump does kick on and prime. I just don't know if it's a cam or crank sensor. Or anything else.
normal stuff..
check compression, fuel, spark..
note .. cam gears are often installed incorrectly .. you wan the 2.4l side
Had this happen to me. The little pin sheered that holds the cam gear to the cam itself and the gear rotated. (common issue, and found the fix on here). make sure your Cams are aligned with the cam gears correctly, or you can loosen the bolt and re-time the cams to the gears.
