does anyone know a safeway of removing the cross on the front bumper without making the front bumper look stupid or no paint where the connection points are? thanks....:thumbsup:
I've seen people do it with a dremel or any sort of sharp crafting knife. Afterwards you need to add fiberglass? I believe to re-paint the spaces you'll end up having.
sounds good thanx appreciate it...
I only cut mine out because I hit a carpet on the freeway. I would say don't do it. But if you really like it just use a nice good qaulity razor. Just be carefull not to cut yourself. If you really need to fill in the little cuts (I didn't care to do it you can't even tell unless you are planning on becoming a show car)
To fill it you need to know how to do body work. It's pretty much sanding fiberglassing, sanding again, prepping, painting. If it's your first time do not do it.
yea so any sharp razor and cut across it as close as possible then....?
Discussion Starter · #8 ·
coo thanx guys...:)
