You can use any octane you want from 87-116. 91 is recommended because the stock pcm is tuned to produce the most power off of it. 93 octane isn't going to hurt your car at all. I only run 94 all day every day :thumbsup:CootersSRT4 said:
You can use any octane you want from 87-116. 91 is recommended because the stock pcm is tuned to produce the most power off of it. 93 octane isn't going to hurt your car at all. I only run 94 all day every day :thumbsup:CootersSRT4 said:Is 93 octane safe for stock car. it says 91 is the highest recomended but the boost psi will go up with 93 so is it safe
You need something to raise the boost eg wastegate or boost controller.CootersSRT4 said:Thanks is it true that the higher octaine the high the boost psi will be
This is true, but not a good idea unless you have a DP without a cat. Run anything other than pump gas through the engine more than 2-3 times, your cat will be destroyed and performance will suffer.GAngel said:You can use any octane you want from 87-116. 91 is recommended because the stock pcm is tuned to produce the most power off of it. 93 octane isn't going to hurt your car at all. I only run 94 all day every day :thumbsup:CootersSRT4 said:Is 93 octane safe for stock car. it says 91 is the highest recomended but the boost psi will go up with 93 so is it safe
VP Racing fuels MS109.CootersSRT4 said:so whats the highest octaine pump gas you can use without damaging anything
