14psi_on20s said:
post your mods dude. it will help a lot
14psi_on20s said:Every time I post whats wrong with my car in the tuning section It gets deleted. I need help tuning my car because its running rich (code) Po172, and It runs like dudie...any help please.
doesnt matter if im pulling 10% fuel or 0..........the car runs the same no matter what...theres something wrong somewhere. Ive read things from it being a gasket or even replacing the orings on the injectors...On another note my e-1 is perfectly fine but im going to post it for sale here pretty soon....along with my 19's for 300$$$ and stockers..jdmoore144 said:how much fuel are you pulling???
hey hector you never let me know if going back to the stocker fixed your boost problems?14psi_on20s said:doesnt matter if im pulling 10% fuel or 0..........the car runs the same no matter what...theres something wrong somewhere. Ive read things from it being a gasket or even replacing the orings on the injectors...On another note my e-1 is perfectly fine but im going to post it for sale here pretty soon....along with my 19's for 300$$$ and stockers..jdmoore144 said:how much fuel are you pulling???
dude not to be mean but i think you owe some people apologies.14psi_on20s said:doesnt matter if im pulling 10% fuel or 0..........the car runs the same no matter what...theres something wrong somewhere. Ive read things from it being a gasket or even replacing the orings on the injectors...On another note my e-1 is perfectly fine but im going to post it for sale here pretty soon....along with my 19's for 300$$$ and stockers..jdmoore144 said:how much fuel are you pulling???
why dont you think its necessary unless you are pushing that much power. a safc is so you can fine tune. its so much better than a regular mapclamp. a returnline and stock injectors can only do so much and with the turbo he was using you would need bigger injectors.srt403 said:car should run 14.2 at cruise and somewhere in the 10-11's at WOT under good conditions.
Why are you running a stock pcm with BIG injectors at stock fuel pressure?
But that aside, it would seem your aem wideband may be off based on your description. You say your lean (based on your af readings) but the stumbling may indicate rich. You should get the rest of s2 kit, and ditch the map clamp. Also a fuel return system is nice to have so you can tailor your fuel to your liking. I would also get your wideband/02 sensor checked. Of course since you have a safc2, what have you tried to d in terms of fueling? Personally unless you are running a big turbo set-up and looking for 400+ HP, a safc isn't nessecary.
later,
Cindy
jdmoore144 said:why dont you think its necessary unless you are pushing that much power. a safc is so you can fine tune. its so much better than a regular mapclamp. a returnline and stock injectors can only do so much and with the turbo he was using you would need bigger injectors.srt403 said:car should run 14.2 at cruise and somewhere in the 10-11's at WOT under good conditions.
later,
Cindy
jdmoore144 said:dude not to be mean but i think you owe some people apologies.14psi_on20s said:doesnt matter if im pulling 10% fuel or 0..........the car runs the same no matter what...theres something wrong somewhere. Ive read things from it being a gasket or even replacing the orings on the injectors...On another note my e-1 is perfectly fine but im going to post it for sale here pretty soon....along with my 19's for 300$$$ and stockers..jdmoore144 said:how much fuel are you pulling???
on another note. go back to the stock injectors and see if that helps.
14psi_on20s said:jdmoore144 said:dude not to be mean but i think you owe some people apologies.14psi_on20s said:doesnt matter if im pulling 10% fuel or 0..........the car runs the same no matter what...theres something wrong somewhere. Ive read things from it being a gasket or even replacing the orings on the injectors...On another note my e-1 is perfectly fine but im going to post it for sale here pretty soon....along with my 19's for 300$$$ and stockers..jdmoore144 said:how much fuel are you pulling???
Well if thats the case im sure I didnt mean it, Wellif anyone has stock injectors Icould definetly pay for them this friday...at this point I definetly think im going to be going a different route with the car. I just want it running strong again for the meanwhile. Hell my friend has had my car for over a year now(240SX), ive given him money on occasion and the other day I called his shop # and no answer.
