Bump.,,
S2R0T044 said:Either post up a sample of the noise or explain it better. Stock, I know our cars occasionally 'blip' and sound like they're misfiring. Without a better description or an actual example, it'll be hard to tell if something is wrong.
Is there a difference when the engine is cold vs. warmed up/hot? I'm pretty sure this is normal for our cars. Still, you are obviously NOT stock anymore...so it's possible something is off.JSMITH said:S2R0T044 said:Either post up a sample of the noise or explain it better. Stock, I know our cars occasionally 'blip' and sound like they're misfiring. Without a better description or an actual example, it'll be hard to tell if something is wrong.
Yeah, I will try to record it today. When idling it will randomly pop thru the exhaust. There is no change in rpm, on the wideband, or the boost gauge. I dont know of a way to explain it any better.
Thanks
Well, as you know, there's a period after the reset where the PCM is tweaking itself and learning your driving habits. I really don't think it's anything to worry about. When and if you can, post a recording of it so we can listen. I'm guessing it's like any other SRT-4 idling.JSMITH said:Yes, It seems to do it way more frequent when its hot. Again, I just dont understand if I can reset the cpu and it will not do it for a couple days.
