Status
Not open for further replies.
This sticky will be for DCR testing and racing results included with timeslip info, videos and build specs. :thumbsup:
Discussion Starter #2 (Edited)
DCR Street 9 testing...
Track conditions went away in the afternoon but here were the results.
1st pass and video... http://youtu.be/iTSyEKs3DcE
1.75 60ft
4.78 330ft
7.20 1/8
103.09 mph
9.29 1000ft
11.06 1/4
127.84 mph (Darrell made a pass on gate pressure=14psi boost)
2nd pass and video... http://youtu.be/ZFJ0hQpIY9w
1.76 60ft
4.86 330ft
7.10 1/8
113.30 mph
8.95 1000ft
10.50 1/4
149.13 mph (Car spun thru first and second had to pedal thru second and 37psi boost)
3rd pass
1.68 60 ft
4.50 330ft
6.73 1/8
113.79 mph
8.59 1000ft
10.15 1/4
144.09 mph (Turned boost ramp rate down due to tire spin prior run 37psi boost. Hooked decent but still excess wheel speed due to track conditions)
4th pass and video... http://youtu.be/voRukex53m4
1.71 60ft
4.58 330ft
6.79 1/8
114.18 mph
8.64 1000ft
10.19 1/4
143.12 mph (Track was getting loose spinning bad 1st and second gear same 37psi boost)
5th pass and video... http://youtu.be/m4qYksntuS0
1.77 60ft
4.69 330ft
6.91 1/8
114.73 mph
8.75 1000ft
10.30 1/4
146.60 mph (Track was real bad thru 1/8th turned boost up to 38psi)
There is a lot of performance left in this car. Installing wider tires!
Full street driven with air conditioning and power steering 29mpg and full Kish 10 pt mild steel cage with window net and chute. This car is heavy and exceeds full weight. Meets all NHRA and IHRA rules! Passes any tech inspection with no issues. Darrell was driving customer car on test passes at Mid Michigan Motorplex(Stanton MI) June 2011. Spun hard top of first and bottom of second! New 2011 DCR High Output 2.6L Stroker Engine. DCR Pro Mod Head. DCR Street 9 Turbo Kit with Bullseye 68mm Turbo with DCR Custom Turbine Housing and Compressor Cover. DCR 3.5inch Full Exhaust. DCR Street 9 Pro Mod Intake. DCR Coil On Plug (Pencil Coils)-w- MSD DIS-4. AEM EMS tuned by Darrell Cox. DCR 3speed Auto Trans. 1st 149 mph full street SRT4!
DCR AEM EMS Tuned Dragster...
My brother in laws dragster 1st time out testing video...
YouTube - ‪Kip's Burkhardt Racing Dragster "Krazy Kritter" aka "Johnny 5"...‬‏
Also the 8.23et @ 162 mph...
http://youtu.be/Z4ui207K9ME
Kip Burkhardt's Dragster aka "Krazy Kritter" and "Johnny 5". ShopHemi.com All Motor Dodge Motorsports R5P7 358ci Small Block with Power Glide fitted with TCI low 1st gear and custom TCI Converter. Cox Performance (aka) Darrell Cox Racing Custom Electronic Fuel Injection on methanol. DCR AEM EMS 2 Stand Alone Engine Controller running with a MSD Digital 6, (8) 1600cc Injectors. Tuned by Darrell Cox. Kip owns, maintains and drives. Darrell Cox handles all tuning. 1st time out and we also went 8.20s this same day. This car will go 7.70s soon as we have since changed gearing and will get more aggresive with tuning. Built in memory of Mark, Jr and Marlene Burkhardt.
Status
