1 - 16 of 16 Posts
I bought the Turbo XS RFL and the Mounting kit. The mounting kit comes with a pressure pipe for the BOV. The problem is on the pressure pipe in the Turbo XS mounting kit there is no inlet for the sensor that is on the stock pressure pipe. Do i drill a hole and put a gromet in for the sensor...or what? Anyone with this BOV/Mounting kit that can help would be appreciated..
you can do it that way, or just cut a piece of the piping out and install the new pipe in the tube too. The new pipe doesn't have to replace the factory hard pipe.
James
you are not replacing the whole pressure pipe. You can leave the section where the sensors are alone. i think you are talking about the hard part in the stock cold pipe. The adapter pipe isn't made to replace the hard part. It made to just work as an insert in the soft part to give you something to mount the RFL to.
Discussion Starter · #8 · (Edited)
....figured it all out.... :cow:...now.... :thumbsup: should i mount on cold side of intercooler...or hot side....i was thinking hot as
to not waste any cold air...or is it more personal preferance.....there was a thread a while ago discussing this....
I see now, you got the AGP style mounting kit that goes on the hot side of the rubber IC hose.
Now i see where to confusion was at!
there should be no sensor mounting hole since that mounts on the hot side.
Is it better to use the Turboxs mounting kit, or is it better to get a hard pipe?
as far as i know, at the moment i don't think there are any hard pipes avaiable that you can mount the turbo xs' on.
Modern has the ATP pipe with Turboxs flange
Discussion Starter · #14 ·
Yeah...i had people tellin me two different things....hot side and cold side....I got it all worked out...thks all....
which side are you going with out of curiousity
1 - 16 of 16 Posts
