Hey this is my first time posting on here so I apologize if I’m posting in the wrong place or if I’m not posting this properly, My car is a mostly stock 06 Chrysler 300C SRT8 with about 100,000km on it and it’s been sitting for a little over a year cause I was away and I’m just wondering if there’s anything I should do to it or check before I start it up and start driving it again? Thank you.
Oil change, and if you don’t want to do one, then disconnect the fuel pump relay and crank the motor to build oil pressure, then put the relay back in and start the car and let it run. Gas sitting for a year isn’t that bad more of oil not in the top of the motor and everything is in the oil pan
Sent from my iPhone using Tapatalk
