just cut and pasting form preformance mods section seeing as you guys wont get to see this till monday most likely.
ok i installed a set of AGP hard pipes on my 05 srt-4. i went by AGP the other day because i had a question on the vac lines, and pulling code p1188, after them telling me the code will stay till i get stage one or higher and fixing the vac lines ive come across a new problem. WHen i shift out of gear under boost into a higher gear, between the gears the engine rev's up around 500-1000 rpms above where i was idling. how would one fix this? is it just that i need to harden or soften my BOV ajuster thingy nut? or is it more compicated? Ohh it also takes longer than usuall for the rmps to go back to idle postion when i come to red lights and what not.
before some one says it, My foot is off the throttle when i begin to shift, do its not my fat lead foot.
car only has 600 mils on it, could it still be the tps?
