1 - 3 of 3 Posts
· Registered
i was just wondering what kinda of fuel setup you guys using wet shots are using? i was looking at maybe getting the NX wet kit for my 2004 SRT. here is my delima. i want to get atleast 275whp on the stock turbo NO SPRAY. i figure if i get all the major boltons (S1, AGP WGA, MBC, turbo back exhaust, hard pipes, CAI, Intercooler, etc) i should be able to acheive that number on the stock turbo. but what am i going to need to do to my fuel system to make sure im getting enough fuel when im spraying nitrous? im shooting for around 350+whp when spraying. if i keep the S1 injectors, and just get a walboro 255lph fuel pump, with the NX wet kit, can i safely achieve these numbers, or get close? or am i going to need more fuel mods?
· Registered
You can do it bone stock man. The OE pump is good to low 300s easily. Just follow the jetting for 58psi and you will be good to go.
· Registered
i tapped into the schreader (sp) valve at the end of the fuel rail with a special fitting available from NAPA, then used a union to adapt that fitting to the braided line and ran it right to the fuel selinoid. i have a fuel psi guage and i just watch it to make sure i'm running safe fuel pressures. this makes the fuel part of the install a snap and if you ever need to, its alot easier to pull the system out and take it in for dealer/warrenty work.
as for your HP aspirations, i see no reason why the stock setup could not handle 325hp. you are talking about putting in the welboro pump you will be fine for sure. i'm running a 75 shot on stock system with only and intake. the car runs like a dream under spray. when i had my 50 shot nozzels in i got it dynoed. did 273hp at the wheels. it had a 57 @ wheel HP increase from stock dynoed HP of 216.
http://www.srtforums.com/forums/showthread.php?t=86122&page=1&pp=15
1 - 3 of 3 Posts
