1 - 3 of 3 Posts
I am in the process of hooking up a TurboXS dual stage bc and I'm mounting the switch on the center console. When I removed the console there are two harneses, one large one which looked to be something to do with the air bag system, and a smaller 3 wire harness that stops right by the hand-brake assembly with nothing clipped into it. So since I need a power source for the switch, I was wondering if anyone knew what that harness is for, and could I use one of the wires for my power source?
The wire colors on the harness were as follows:
green w/ white stripe--switched power source
purple w/ yellow strip--still no idea
black w/ pink stripe--ground
I was planning on useing the lighter for a power source but this is closer. If I can use one of the harness wires, great. If not, i'll go back to my original plan. So if anyone knows please post up. :thumbsup:
Found my answer and edited for future reference.
Technical Tuning & EFI/EMS Electronics moderator
Yeah, you can pull power from that unplugged 3wire connector. I don't know which one is power, but one of them is a switchable 12 volt source. Get a meter out and check'em.
1 - 3 of 3 Posts
