1 - 15 of 15 Posts
I installed the turbo wrap kit on the turbine side housing like the instructions say, but I was wondering if the wrap should be tight/flush along the turbine housing or should in be baggy/loose like in the pics with some extra room inside the "wrap"??
how can I order up some more 20" stainless locking ties because I need more to use on another turbo...thanks!
I like the kit alot!! it also comes with header/downpipe wrap which helps keep the exhaust gases hot and up to speed inside the dp...I also like it because it keeps a lot of the heat from the rest of the engine bay.
turbo wrap
Great to hear the positive comments. The SRT-4 needs its turbo wrapped as much as any other vehicle. I suggest wrapping the turbo, protecting the plug wires, and using our air tube cover or exhaust wrap to keep the incoming air cooler.
turbo wrap.
14" S/S locking ties are availiable (P/N 010202) at your dealer. Leaving the turbo wrap a little loose will not hurt anything, just will leave a little air barrier, but will not look as neat a tightly wrapped install. Its personal preference, just make sure it is very secure installation.
thanks for the reply...i have the wrap nice and tight against the turbine housing which looks really good!! I'm about to swap out my T3/T4 for a Precision GT turbo and am going to be wrapping this one too...I recommend this kit to anyone that has removed their turbo heatshields!!
Lets see some pics!
I have the boots on my plug wires, and the CAI wrapped also.
Discussion Starter · #8 ·
I don't have a digital camera, but when I wrap the turbo/dp later this week, I'll try and post up pics on this thread...
pm sent
Discussion Starter · #11 ·
thanks for the info....I think summit racing sells lengths greater than 14", but not positive...If I can't find any bigger I'll be ordering some from you...
Discussion Starter · #13 ·
the kit comes with enough wrap to do the turbine housing and either your dp or manifold....you can always buy more heat wrap and do everything, which I might do down the road...
Discussion Starter · #15 ·
generic kit with enough materials for a couple of stock turbo/manifolds....except the stainless locking ties..they only give you 4, but I found a 20' roll of them from thermo-tec or something like that...
1 - 15 of 15 Posts
