Well I just purchased your Frount mout chiller and install with tank kit. I was wondering if that could be used with your pruge valve. If so please give me some direction to where I can purchse the purge valve.
Purge Kit
Yes, our purge kit can be used with your present CryO2 system. You will just need to purchase our complete purge system that will include line and an additional solenoid.
Have you installed this yet? How do you like it?
Purge pictures
here are some pictures:
Jon for some reason When I purge you can't see anything. but you can feel it comeing out please tlel me what is wrong.
purge
1) make sure the bottle is mounted correctly. The label should be facing up with the hose fitting facing down. Its also important that the tank is also mounted on the brackets for the correct angle.
2) Make sure the gas distributor is filling you bottle with liquid CO2 not just vapor!
purge
See if this helps!
