1 - 3 of 3 Posts
I just got the kit and have installed all the hardware, electrical work will be done tonight. My question is the allen wrench and the pump??? I have the progressive controller...I have yet to look at the setup, does it come preset, is it all the way clockwise, ccw? If you could please elaborate on what i need set this little bitty at or some info on which way i should be turning for tuning and stuff, much appreciated, thanks.
This is how the pressure switch and the pump actually work
http://www.devilsownonline.com/forum/viewtopic.php?t=221
As far as preset with the new switch we use a M3 will be at 180psi and a M5 will be at around 165psi. The pressure switch does not controll much in the actuall psi of the pump. Less than 15psi difference, it simply has a set off and on point.
Use your controller to controll pump output not the pump adjustment bolt. Turning the controller higher than the boost you make reduces the over all pump pressure through PWM.
There is really no reason to play with the pump with the progressive set up.
1 - 3 of 3 Posts
