about to order a ptp wastegate... car is an 05 stock with exception a MBC,k&n, and rice plate.... the ptp shoudl be able to get me to redline around 15 psi correct?? because right now i can spike 17-18 but not hold until redline.....and with the ptp my MBC would be useless right?>or should i just go with a s2 wastegate??
should i connect the vac from the wastegate to the turbo housing or use the solenoids??? right now the comp ISNT controling the boost......and i want it to stay that way lol...
just connect the line from the back of the turb to the waste get when u get the PTP
and boost leak test ftw...i have the WORST leak coming from the stock charge pipe at the turbo. sucks.
T-bolt clamp FTW
jyndrus90 said:
T-bolt clamp FTW
yep yep. this wednesday. ftw.
