Prothane and Energy Suspension Poly Bushing Part #'s
3028 Views 0 Replies 1 Participant Last post by  ewetho
PROTHANE
Chrysler Dodge/Plymouth/Neon, PT Cruiser
BUMP STOPS
(PT Cruiser)
01-06 Rear Bump Stop Kit 4-1301
COIL SPRING ISOLATORS
(PT Cruiser)
01-06 Front Coil Spring Isolator Kit, Lower 4-1704
01-06 Rear Coil Spring Isolator Kit, Upper & Lower 4-1705
CONTROL ARM BUSHINGS, FRONT
(Neon, SRT-4)
95-99 Front C-Arm Bushing Kit 4-209
00-06 Front C-Arm Bushing Kit 4-214
(PT Cruiser)
01-06 Front C-Arm Bushing Kit 4-214
CONTROL ARM BUSHINGS, REAR
(Neon, SRT-4)
95-99 Rear C-Arm Bushing Kit 4-301
00-06 Rear Trailing Arm Bushing Kit 4-304
(PT Cruiser)
01-06 Rear Trailing Arm Bushing Kit 4-302
01-06 Rear Watts Linkage Bushing Kit 4-303
END LINK BUSHINGS, Front & Rear
(Neon)
95-99 Front End Link Kit 4-401
95-99 Rear End Link Kit (sport package only) 4-402
(Neon, SRT-4)
00-06 Front End Link Kit 4-401
00-06 Rear End Link Kit 19-413
(PT Cruiser)
01-06 Front End Link Kit 4-401
01-06 Rear End Link Kit 4-403
MOTOR MOUNT INSERTS
(Neon-SOHC, DOHC & SRT-4)
95-99 Engine Mount Insert Kit, Front 4-501
95-99 Engine Mount Insert Kit, Right 4-502
95-99 Transmission Mount Insert Kit, Left 4-503
95-99 All 3 Mounts, Kit 4-1901
95-99 All 3 Mounts, Kit (Softer Street Style) 4-1902
00-06 Upper & Lower Mount Insert Kit (Race) 4-1905
00-06 Upper & Lower Mount Insert Kit (Street) 4-1906
SHIFTER BUSHINGS
(Neon)
95-06 Shifter Bushing Kit 4-1605
03-06 SRT-4 Shifter Bushing Kit 4-1606
STRUT ROD BUSHINGS
(Neon, SRT-4)
95-99 Rear Strut Rod Bushing Kit 4-1204
00-06 Rear Strut Rod Bushing Kit 4-1206
SWAY BAR BUSHINGS. Front & Rear
(Neon, SRT-4)
95-06 Front Sway Bar Bushing Kit, 20mm Bar 4-1118
95-99 Front Sway Bar Bushing Kit, 22mm Bar 4-1119
00-06 Front Sway Bar Bushing Kit, 24mm Bar 4-1120
95-99 Rear Sway Bar Bushing Kit, 16mm Bar 4-1111 *(Sport Package only)
00-06 Rear Sway Bar Bushing Kit, 12mm Bar 4-1130
00-06 Rear Sway Bar Bushing Kit, 14mm Bar 4-1131
00-06 Rear Sway Bar Bushing Kit, 17mm Bar 4-1137
(PT Cruiser)
01-06 Front Sway Bar Bushing Kit, 22mm Bar 4-1119
01-06 Front Sway Bar Bushing Kit, 24mm Bar 4-1120 *(Touring Edition)
01-06 Rear Sway Bar Bushing Kit, 18mm 4-1136
TIE ROD BOOTS
(Neon)
95-99 Tie Rod Boot Kit (2) 19-1711
TOTAL KITS
(Neon)
95-99 Total Kit (Includes Sport Package) 4-2002
00-06 Total Kit (Neon, SRT-4) 4-2007
(PT Cruiser)
01-06 Total Kit (Includes Touring Edition) 4-2006
ENERGY SUSPESION
Neon
Hyper-Flex System Complete Master Bushing Set
2003-05 SRT-4 -- 5.18114
2000-05 5.18111
1995-99 5.18106
Front End Control Arm Bushing Set
2003-05 SRT-4 -- 5.3129 (57)
2000-05 -- 5.3123 (57)
1995-99 -- 5.3116 (23)
Rear End Control Arm Bushing Set
2003-05 SRT-4 -- 5.7114
1995-99 -- 5.3117
Front Strut Rod Bushing Set
1995-99 -- 5.7110
Front Sway Bar Frame Set
2003-2005 SRT-4 -- 24mm 5.5153
2000-05 -- 20mm 5.5149
1995-99 -- 20mm 5.5144
-- 22mm 5.5120
Front Sway Bar End Link Set
2003-05 SRT-4 -- 5.8107
2000-05 -- 5.8105
1995-99 -- 5.8101
Rear Sway Bar Frame Set
2003-05 SRT-4 -- 17mm 5.5156
2000-05 -- 14mm 5.5150
1995-99 -- 16mm 5.5121 (50)
Rear Sway Bar End Link Set
2003-05 SRT-4 -- 9.8119
2000-05 -- 9.8124
1995-99 -- 5.8102 (50)
Tie Rod Boots
1995-99 -- 9.13103 (72)
Rear Trailing Arm Bushings
2000-05 -- 5.7112
Motor Mount Inserts
2003-05 SRT-4 -- 5.1109
Motor & Transmission Mount Insert Set
1995-99 -- 5.1107
Shifter Stabilizer Bushings
2003-05 SRT-4 -- 5.1110
Foot Notes
(23) Front lowers must reuse existing outer shells
(50) Sport pkg. only
(57) Must reuse all metal parts
(72) 2 Boots per package
Universal Sway Bar End Link Kits for lowering your car
Measured by the length of the spacer sleeve.
1" -- 9.8122
1 5/8" -- 9.8120
2" -- 9.8123
2 3/8" -- 9.8125 -- Works good on a 1.5? drop
2 5/8" -- 9.8117
2 7/8" -- 9.8118
3 3/8" -- 9.8119 -- Stock SRT4 part for rear
3 9/16" -- 9.8124 -- Stock 2GN part for rear
4 1/4" -- 9.8149
4 1/2" -- 9.8121
1 - 1 of 1 Posts
1 - 1 of 1 Posts
