Ok,
I like all the bell and whistles of the eo1 and its worth every cent!
I managed to find a good tach signal which allowed me to take advantage of the RPM off set on the eo1.
Some of us are having problems dropping boost down to 13PSIish after 4k RPM. What happens is that the EBC and MBC orifice are set acheive a certain amount of boost. Well once you go over 4krpm, the boost starts to drop. The reason is because the stock WG spring is weak.
When i set the e01 to 16psi it starts to drop down to 13psi also. But when i go into the RPM offset i am able to raise the gain after 4k rpm. What happens is that above 4k rpm, the solenoid opens more which allows you to maintain boost.
What is happening here is that above 4k rpm, the unit modulates the solenoid to say an 18psi opening to take account of the weak WG spring. So with this unit, there is no need to get a stiffer wastegate spring. YOu can utilize your stock one and hold boost up to red line all day long.
On a manual boost controller you cant do this. Once you set your manual boost controller to a certain setting, its set. It will not modulate to maintain the correct boost. YOur boost will drop down unless you upgrade the WG dashpot or plug up the stock surge valve.
The greddy eo1 is trully a great unit and with the optional harness, you can eliminate fuel cut and have the apexi AFC or emanage acommedate for the extra boost.
Happy boosting!
Happy boosting!
