1 - 10 of 10 Posts
whenever i floor my car at low rpm's it kinda bogs out and shoots out these little backfires really fast and doesnt sound good at all. i was thhinking maybe the engine was getting to much fuel? my mods are agp wastgate, perrin bc, aem cold air, bdj exhuast, ngk plugs, s1.
thanks
Don't floor your car at low RPMS, that's incorrect drivng technique.
There, fixed:)
That sounds odd. I see your mods, but have you messed with any of them. have you done any mods and then undo them?
Give me more info suka. I need more info!
There, fixed:)
ACtualy im with GLH on tis one as far as not hammering it at very low RPM. You will spike like a mad man.
ACtualy glh, your comment reminds me of the a DR.
DR, my arm hurts when i touch it.
DR says, well dont touch it.
lol!
that happened in my car when my ignition wires were going bad...hasnt happened since i replaced them.
To be sure, please define "low RPMS"
SRTFORUM Moderator
hey man, i had a similar problem to mine a while back. Check your TPS sensor, i had a bad wire right by the plug. Shake the wire around, then go drive it. This may help.... it helped me out. hope this helps you... i could be wrong.
1 - 10 of 10 Posts
