Could be your clutch fork being worn if it's original....this was my original from last year with a only a little less km's on it. I'm only at 123k km now. Photo is from last year Apr 21....
That is exactly how mine behaved before I had the clutch and friends done last year....If they're going to tear in, I recommend doing the input shaft bearing as well. Mine just took a dump after only ~a year with everything else new.tbagg1ns is correct, sounds like a worn clutch fork to me also.
The transmission shifts good when the car is moving BUT when not moving, any gear is tough to shift into...clutch fork.
If you can shift easily into first gear with the engine off (but not when running)... clutch fork.
A well worn (100K miles) clutch fork will no longer fully disengage the clutch.
I didn't play around either, that's a lot of work to drop a transmission, cheap insurance just to go new on that stuff. You don't replace a clutch often, may as well replace them.That is exactly how mine behaved before I had the clutch and friends done last year....If they're going to tear in, I recommend doing the input shaft bearing as well. Mine just took a dump after only ~a year with everything else new.
