what spring would you recomend me tobuy
  • tein s techs
    Votes: 2 18.2%
  • ebiach
    Votes: 3 27.3%
  • mopar stage 1
    Votes: 3 27.3%
  • screw all this go coilovers
    Votes: 3 27.3%
I went with the Mopar Stage 1s. Its a 25mm drop which is about 1 inch (like .98 inches or something) and they were designed by those that made the damn car, so performance will be there and they should work fine with stock struts without blowing them out because its a very slight drop, I think goldlines are right where they start go get iffy with damaging the stock struts.
It depends mostly on the look that you want. I would recommend aftermarket shocks for all "sport" springs. Hotchkiss and Mopar will supposedly work with the stock shocks, so if you can't buy shocks look into those. Otherwise just choose which one you think gives the best stance. The springs rates are pretty similar on all of them so handling will be about the same either way.
