Why do people not use the pink vacuum line to hook up greddy/hks Bov's?
I'm about to install a greddy and from what I have found, everyone is T'ing into the black line on the TB.
I'd like to just use the pink line if possible...anyone have an answer?
unplug, cap, it, its a waste lol
Why? Is the line just too small?
You can use the red line for your Greddy BOV. The blow off valve just needs to know when the throttle plate is closed. Close to the throttle body is ideal.
Because when you have a after market BOV you need a block off plate and you will be removing the stock bov which the pink line goes to, so you need a vacum source to run you aftermarket bov and the TB is the one.
