1 - 17 of 17 Posts
I thought the pcv line neeeded to go to the TB because it needed to respond to the pressure from boost and vacuum.. versus the driver's side air make up hose, which just needs an air supply.. correct me if I am wrong
Discussion Starter · #8 · (Edited)
im venting to the atmosphere which is illegal i dont want that bad blownby air goin back into my car to burn so the way im doin it is illegal but works pretty good. the catch can will never be pressurized nor will the crankcase cause the air will be forced out of the can. it only becomes pressurized under boost cause boost pressure keeps the pcv system closed only opens up under vaccum thats how it is however u install it
Discussion Starter · #9 ·
u would only need an air supply if the catchcan was not vented
Did you paint that part where it says 2.4L TURBO or is that a sticker overlay? If it is a sticker, do you know where I can get one? :)
Looks great, good job on that. I might try to do that. Although I don't know what color I'd use.. Maybe red..
Dude, your dog is my dog's twin! BTW- car looks good.
easily!
1 - 17 of 17 Posts
