I've searched the forums for pics of srt4's with the h-techs installed and I only found 1 in which they were supposedly installed backwards. :tongue:
So... does anyone have a pic of an srt4 with the h-techs installed... properly? :frogtongu
Tein H-Tech springs on 17x7 wheels and 225/45ZR17 tires.
do you scrape when turning in anywhere?? How is the ride/handling compared with stock?
i've read elsewhere that no camber kit is required for H-tech......seems a different opinion everywhere.
Also heard that if you cut the bumpstops about 30-50% you won't bottom out.
Any responses?
I had my springs installed by a reputable shop, Speedmerchant, in the Bay Area. They have done many spring and coilover installs on the SRT-4. Their tech. told me I needed a camber kit, so I got them. I don't think they cut the bump stop either.
Also, although the edge of the fender and the top of the tire is not on the same plane, a visual check using a ruler shows that the "gap" between the top of the tire and the edge of the fender is about 1" front and 1 7/8" rear.
