Hello all, it’s been awhile for me. To quickly catch up, my car is running strong and healthy with the BWS turbo, and just recently made the switch back to 91 octane from E85. It is time for some general maintenance, inspections and cleaning.
My main topic is regarding the PCV and drivers side valve cover outlet. For as long as I know this has been an ongoing discussion for many years. I’ve seen DCR’s write up on how these engines need vacuum under boost via the drivers side port being hooked up to the air intake, and I’ve also seen another post where it’s the opposite, stating to remove the line and replace it with a breather filter. Also, I am aware that our factory PCV valves leak a little bit under boost. Since I cannot find a solid answer, my question is what is the best and only way to have it properly hooked up in 2022?
My setup is pretty much factory form. I have the original pcv valve running down to a Catch can, then a Bwoody check valve in between the catch can and throttle body. The drivers port of the valve cover is hooked up directly to my Air intake. Does the factory PCV need to be gutted and put a good working check valve right after the factory one to prevent crankcase pressure? Please let me know if anything is out of the line.
