Hi, I will put on my SRT a Stage 1 with WGA Stage 2. I will spike at 18 psi and I hope that I will not have probleme with Part Throttle Boost....what do you think about that??? I don't want spend money again for my SRT :(
adjust the arm/nut o nthe wga for lower boost...
I used to run with a stage 2 wga, PTB was barely there and noticeable so you will be fine.
instead of that s2 wastegate - put a mapclamp in - keep lines stock & hold on :) Make sure you use a dyno to tune it - or even better, get a AFR meter. It is something you will always use and you can get better/real time tunes - as tune from a dyno is will give you very different results in the street.
Discussion Starter #6
I've got my Stage 1 and ma WGA S2 but I didn't put them yet. I don't want spend money again for a Map clamp or a Dyno set up. Is there someone who have this set up (set to spike at 18 psi) and can say me if he has PTB.
thanks
