1 - 7 of 7 Posts
Does anyone else have this problem? I try to drive carefully, but with a MBC on the car spools so fast that I keep throwing the TIP code. :(
Do the EBC's have this problem, too?
ok, details.
It's just a do-it-yourself type boost controller, ball & spring.
It's T-d off the 3" or so piece of black hose coming off the compressor housing. Goes from there to the MBC to the wastegate, then the stock wastegate hose is capped off.
Ah ok.
Thats where I have mine hooked up to. As long as its ont on the gree vacuum line.
For some reason, some of us get it and some dont. These ECU are not consistent. I think its cause you hit boost so quick with only part throttle openings.
I know i have been overboosting lately when i go to part throttle on it at 2200 rpm, i would over boost. IM goign to limit my boost to the stock 11 psi then have it do 15 when i hit 2800 rpm. I will see if it triggers my cel or not.
boost
Yeah, I've noticed that some people seem to hit CEL's on similar situations that others don't. Weird.
I'm waiting to see about the UTEC from TurboXS. Seems like a real good unit that could help solve some of these issues, but I'm not sure when it's going to happen.
On a positive note, can't wait to see what that Mopar Stage 1 does. Soon. :D
1 - 7 of 7 Posts
