So I was driving 05 srt4
And my check engine light came on and while I come to a stop the car bags down sometimes.So I checked the codes it’s giving a P0508 code and p1106 code. Next day I try to start the car and wouldn’t start until the 4th time but it will try to crank over. And finally started now it just won’t start anymore but it will try to crank over. NEED help thanks
P0508 Idle Air Control Circuit Low
P1106 OBD-II Trouble Code: MAP/BARO Pressure Circuit Range/Performance Problem
Check for loose/missing/cracked vacuum hoses. I'd also look for vacuum leaks.
I replaced the iac valve dident make a difference still trying to crank hard I replaced spark plugs and got a new coil pack got codes p1106 p0522 and p0038
I’m stuck and don’t know what it could be I need a new turbo exhaust manifold the car sounds awful cause exhaust leak but I don’t see how that can effect because it started before like that
