P0073-AMBIENT TEMP SENSOR HIGH
That is the caod. I thought that I capped all of the lines and ensured that all wires were hooked back up.
The car pulls like a mofo. Boost is holding right where Ihad it dialed in. I jumped through the first 3 gears quick. well quicker than normal.
The only bad thing is that caod.
NE help appreciated.
Discussion Starter · #2 ·
well reset the PCM and will see if that corrects it. I restarted and it was not their so we will see tomorrow morn. Either way it did not seem to hurt power so If it comes back on tomorrow then I can look a little further while I am at work.
sure you hooked all your sensors back up... that's weird. The only sensor I can think of off the top of my head in that area is the air intake sensor that goes in the little elbow off the stock air box. or if you have a after market intake it goes into the intake some where.
Well after the ecu reset . the drive to work all is good. The PTB is gone or mostly. on the few test runs in third pulled bout the same maybe a little better. @ 4am I try not to get to crazy well atleast on a holiday weekend.
i just took my car to the dealership because i had the code p0073 going off. they looked at it and decided that there was a bad ground to one of the lines. so they regrounded it and it solved the problem.
help what ground was i1t
what ground was it
Discussion Starter · #8 ·
I would look at either the ground near the Starter or look at the ground connection on the battery. As far as the battery that the other guy is talking about I have no Idea. A ECU reset had fixed the issue and I have not had that issue since.
