my stock boost numbers are down to 10-12 psi all clamps tight, bfmic and stock turbo i am throwing p0073. would the ecu pull boost back a bit from this code?
P0073....Ambient Air Temperature Sensor Circuit High Input
vacuum lines, clamps, look for tears or holes in vacuum lines as well.
will do and thanks im taking it to the dealer tomorrow for the sensor cause its screwed i thought that maybe the ecu would pull boost cause it couldnt determine the air temp at the intake any thought on this
did you touch the sensor on your intake? if so make sure it's in tight and the red clip is the whole way down. then try resetting your pcm.
a high input could be the result of faulty wiring.
