does anyone know why I would be getting code 0234, which is overboost performance? I installed the AGP WGA and TurboXS HP boost controller last week, along with the Mopar BOV. I have the WGA set at 11-12 psi according to boost gauge when no boost is dialed in on the boost controller. I have the boost controller set to spike at 15-16 psi and hold around 14. Is this too much for stage 0 or is something else wrong? Please help me get this figured out. Thanks.
I have the stage 1 pcm in my garage. I just haven't got in contact with Flight Systems to get it flashed. So is this code normal for Stage 0?
yes I have seen it on my 2004 which is stock except for a stage 2 wastegate with boost tuned up alittle...
disconnect the negative terminal on the battery, step on the brake, then reconnect, code should clear...
also, your dealer may be able to re-flash your stage 1 pcm...
