Ok..where is the oil filter located on the engine and oil drain plug?
So much for the owner's manual.
I dont' have one yet, however, there are detailed pics in the Winter 2003 MOPAR Now Mag, pages 38-39. It shows the oil filter and drain plug just off center of the engine on the bottom and towards the fire wall. Oil filter is mounted horizontally and attached to an oil cooler. The drain plug is facing away from the front of the car and next to the filter. I hope this helps and is not confusing.hemidakota said:Ok..where is the oil filter located on the engine and oil drain plug?
Good Deal!! I'll keep that in mind when mine is due for a change.hemidakota said:Found it.
I had to jack under the passenger front tire area and in the middle is the wonderful oil filter and beside that the drain plug.
The K&N 1002 Oil Filter will still work but I am looking for another one that is longer but same width. The Neon HP1002 is less than 3/4 inch smaller in length but it will make no difference due to the volume the oil filter can clean over sny oem version.
In would caution anyone when you want to remove the oil filter, use a oil filter clamp jaw for the first time. The factory tightens the filter so tight that a standard slip on will not work. LOL
It said five quarts in the owner manual but I would add some info, when using a K&N oil filter, it will take at least a 1/2 quart more (due to the the element inside satuation) when running the engine for a couple minutes.
