I've had 3 neons now and on each car I've noticed they get oil around the spark plugs. Has anyone else had this problem? is there a fix for this?
John
Mopar Event Specialist
John
There are round seals that you will find in the valve cover that are meant to prevent that from happening. Oil in the sparkplug well would be from a seal leaking. I haven't seen it with an SRT yet, but it is very possible. It is especially possible if you have had the valvecover off...
Dale
it has happened to mine.. the number 3 spark plug has been drenched... took it back they replaced the seal, then it happened again after a thousand miles went past, took it back, they replaced the head and the valve cover...
